tranny oil change in a 5-speed gt
At what mileage would you change the tranns oil in a 5-speed? I heard that since its a 5-speed ,i didn't need to change the tranns oil,it's this true?And if i change it to other brand other than motorcraft what would be a good choice(brand)? THANKS
RE: tranny oil change in a 5-speed gt
60,000 or 48 months whichever comes first. They are wrong. It needs to be changed. when I did mine, the fluid was as black as black can get. after the change, my stick shift would no longer get extremely hot after driving for a few hours.
use the original oem oil and nothing else.
ORIGINAL: techsent
Most of us have switched to Royal Purple Syncromesh and have had NO problems doing so.
RP all the way! Use 3 litres or 3 quarts, its close enough. Dont over fill it. I called Ford themselves and they said that the RP would be much better than motorcraft junk
IMO you should change it the day you get your car, regardless of the milage.
This is my thinking because I think everyone should run full synthetic in their trans (and rear/engine for that matter). Full syn ATF FTW!
ORIGINAL: 2000GT4.6
