2v to a 4v swap
2v to a 4v swap
Hey I have a 99 gt 5spd and I want to go to a 4v engine since my plan is too TT it what would all be involved with the swap I asume I will need a wireing harness and gauge cluster but I am sure there is other stuff involved with the swap can any of you please enlighten me
RE: 2v to a 4v swap
well what year 4v are u swapping in, cause if you wanna do a TT and u dont have a terminator block your probably gonna pop the motor, you will need the ECU, wiriing, and the complete motor, correct length throttle cable, and a flywheel to correspond with the different bolt patter on the crank.
RE: 2v to a 4v swap
I have quite eextensive dataloggin skills so the ecu should be a problem Its aaccualy part of the reason I want to do it because I want to do somthing new all I have really been doin is subarus supras and diesel trucks< dont ask where it came from. Anyways thatnks for the help man oh the the engine is out of a 03 mach 1 that was tboned
RE: 2v to a 4v swap
you wouldnt need the ecu or wiring harness if you have a good tuner
Matt's 95 Stang
10-05-2015 07:16 AM
