Porting and Polishing Stock Plenium and Throttle Body
Old Aug 24, 2007 | 11:23 PM
darthvader's Avatar
darthvader
Default Porting and Polishing Stock Plenium and Throttle Body
Is there any directions on doing this? Any suggestions?
Old Aug 24, 2007 | 11:41 PM
livefast1's Avatar
livefast1
Default RE: Porting and Polishing Stock Plenium and Throttle Body
you can knife edge the butterfly, grind down a little of the protrusion in the retaining bar, use flush, triangle headed screws instead of the bubble shaped retaining screws. remove metal from the circumfrence of the tob but not on the butterfly landings. you can remove a pretty good amount of metal from the upper plenum especially around the egr area and where the air enters the lower intake on the throttle side.
Old Aug 24, 2007 | 11:53 PM
LetThePoniesRunFree's Avatar
LetThePoniesRunFree
You're going to spend more time and effort into p/p your factory parts than it would be to just buy aftermarket with the same gains.
Old Aug 24, 2007 | 11:57 PM
livefast1's Avatar
livefast1
not if hes bored on a saturday, only took me a couple of hours. in all reality i would probably buy a 75 mm throttle body but i would still p and p my stock plenum, i saw a test where a properly ported upper plenum could flow as well or out flow pretty much any aftermarket one.
Old Aug 25, 2007 | 12:02 AM
livefast1's Avatar
livefast1
plus its free. i know the butt dyno isnt the most accurate but i really did feel a difference. it wasnt much but it was pretty dam good for the price
Granatelli Sales
Jan 20, 2020 12:34 AM
copestang
Oct 11, 2015 07:17 AM
zanemoseley
Sep 6, 2015 12:58 PM
TimeLord101
Sep 4, 2015 09:27 AM
5.0 kevo
Sep 3, 2015 06:24 PM
