comp vs. VT
Old Aug 29, 2007 | 06:27 PM
tbirdscwd's Avatar
tbirdscwd
Default RE: comp vs. VT
To get optimal performance and to cover your ***, you should degree any set of cams you put in your car. Granted, its more of a must when you deal with Comps because of the advance ground into them.
Old Aug 29, 2007 | 10:49 PM
GhostRider02GT's Avatar
GhostRider02GT
VT stage 2, with comp springs and adj cam gears, thats my plan anyway....
Old Aug 30, 2007 | 12:30 AM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: klfutrelle
Go with stage 1 if you are not going to do anything else.
Stage 2 if you are building the whole motor.
Blower cams if you plan on supercharging
Its unrealistic to try to buy a cam now in planning on building the motor later. If your build the motor, your going to want a custom grind, or at least more than a stage 2 cam is going to offer.
Old Aug 30, 2007 | 12:33 AM
jEEd's Avatar
jEEd
I ♥ Acer
ORIGINAL: mrounds06
i have found 2 really good deals on vt stage 1 and comp 262ah camshafts. which of the two would i be better off getting? my 00 gt has a stock bottom end, whats the largest cam i can go with? all info appreciated
mind telling me these really good deals you found for a vt stage 1 cams!? :]
Old Aug 30, 2007 | 12:34 AM
2000GT4.6's Avatar
2000GT4.6
VT FTW BTW
Old Aug 30, 2007 | 10:03 AM
y2kStangGT's Avatar
y2kStangGT
ORIGINAL: tbirdscwd
hey i don't know anything about engine.
what do you mean by degree?
Old Aug 30, 2007 | 01:32 PM
tbirdscwd's Avatar
tbirdscwd
The cam timing should always be set or "degreed" during installation to ensure the engine runs properly and to avoid contact between the valves and the pistons. The rotation of the cams has to be timed correctly in relation to the crankshaft. There are some really good cam threads on here that can explain it way better than I can.
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
junior04
Sep 28, 2015 10:53 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
Luke9222
Sep 4, 2015 06:46 AM
