Timing Adjuster
Originally Posted by Black Horse
Originally Posted by GT99GT
what exactly does the timing adjuster do?
It allows you to adjust your timing from the stock 10* you caneither retard or advance it...Its A GREAT PRODUCT AND MAKES A HUGE DIFFERENCE</P>
</P>
Blackhorse, was that you on the pic last night?..sorry man/.......I didnt meant to call you ***,...and answering the question for this guy, he knows that it is a tool to retard the timing, he needs to know actually what is retarding.....</P>
Can the timing adjuster screw anything up or does it just add HP and thats it. i mean , ive heard some bolt ons can cause problems like underdrive pulleys causing overheating problems and undercharging the battery.... i dont want to put any mods in that will screw up something else.. know what i mean
http://www.chevyhiperformance.com/howto/97438/</P>
Good article about timing and how to use it to your advantage.</P>
Hey guys... I have a Superchip and it claims to bump up the timing to 14 degrees. Is this even possible and if so should I even look into getting a timing adjuster because my timings already bumped.. or am I just a complete moron.
well if you already have your timing bumped to 14 degrees and dont ever plan on getting a power adder (s/c, turbo, nitrous) then you dont really have a need for the adjuster. if you plan on adding a power adder though its a must! You can change your timing in like 2 mins! super easy
</P>
I'll go for the later.......................................<IMG src=smileys/smiley8.gif border="0"></P>
