02 sen
02 sen
i installed mac lts and h pipe and when i did this the 02 sen cable wasnt long enough so i cut it and made it longer will this cause my idle to go crazy and cel to come on oh and i also have mil elim
RE: 02 sen
it shouldn as long as you connected the right wires together, and did you solder them and use the shrink tube on it, or did you use the solderless crimp connecters? i would solder them if you went that route, but you could have also bought 02 sensor extensions specifically for that reason, so you should b fine
Samwell121
09-25-2012 11:34 PM
