5.4 boost
Old Sep 22, 2007 | 05:48 PM
livefast1's Avatar
livefast1
Default 5.4 boost
hi could anyone tell me if the stock blower on a cobra would produce more maximum output power on a 5.4. i know the cobras max out at like 450 to 500 with this blower and i assume at the same amount of boost the 5.4 would make well over this.
Old Sep 22, 2007 | 06:25 PM
Triisomy21's Avatar
Triisomy21
Default RE: 5.4 boost
The only one that would work is the Lightning blower. The blower from the cobra wont even fit.
Old Sep 22, 2007 | 08:12 PM
oxfordgt's Avatar
oxfordgt
+1
Old Sep 23, 2007 | 07:20 AM
livefast1's Avatar
livefast1
actually the blower would fit. use navigator or 0304 cobra heads (theyre different navigator has bigger ports) and reichard racing adapter plates.
Old Sep 23, 2007 | 01:33 PM
Triisomy21's Avatar
Triisomy21
Sounds like a pain in the a** man.
If you can easily get cobra heads why not stick with a 4.6 block and save up for a KB or whipple?
Any reason why you're going with a 5.4?
Old Sep 23, 2007 | 03:04 PM
2000GT4.6's Avatar
2000GT4.6
I have no personal experence, but I don't think it would work really well for that setup. Remeber that a larger displacment engine requires a blower that will support more CFM for the same level of boost. The stock eaton on the 03/04 termys are not exactly the largest or most efficent blowers out there, increasing from a 4.6L to 5.4L is not going to help out matters.
I would be more looking into either the bigger KB, a vortech T trim (or bigger) novi 2000, or ATI D or larger blower, or of course the lighting eaton if you want to keep it as cheap as possible (and you can find one).
Old Sep 28, 2007 | 04:40 PM
livefast1's Avatar
livefast1
5.4 for more displacement (self explanatory) and navigator heads are the highest flowing modular heads. and thanx for the info on the supercharger.
jwog666
Dec 27, 2021 08:09 PM
TCStangerv6
Oct 11, 2015 05:57 PM
Oct 7, 2015 07:02 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
