steeda x2 balljoints and tire wear
hey im tryin to get a straight answer here....ive been lookin all over, here is my situation.
i lowered my car with the pro kit(1.5 in) and got it aligned. the problem is the insides of the fronts are bald....the tread on all of them is down and i need new tires anyway. but i dont want to be going bald on the insides anymore what do i need to fix this? I heard you do not need c/c plates until after 1.5 inches so i SHOULDN'T need those. my friend has H&R springs(1.8 in) and he has no problems. he also has the steeda x2 ball joints....woudl i be straight and everythign cool if i got the ball joints and got another alignment too? it says the ball joints fix the steering geometry by moving the control arm to line up with the pivot point of the ball joint, would this help with my problem? if all this doesnt make sense then ask me, im going to call steeda tom. and see what they have to say. the reason i want them if they work over the c/c plates is because they also lower the front a lil more and that what i want a LITTLE bit more in the front. so thanx for any information or thoughts/ideas
-Pat
-Pat
RE: steeda x2 balljoints and tire wear
I disagree with the theory of over 1.5 you need c/c plates. You NEED C/C plates with ANY lowered spring!!! The factoryc/c plates are riveted and aren't adj.Yes X2 balljoints will raise your geometry back up to par, but only for cornering and Steering. They will allow you to avoid installing a bump steer kit. The tie rods are adj and fix "toe". The C/C plates fix that tilting in of the tires!
well when i got it aligned they popped out the rivets and put new ones in after they aligned it, so i know thta they are adjustable to a certain point
ORIGINAL: MustangMan00
Lowered 1.5" without CC plates you will only be able to adjust the camber to about -1.2° to -1.5°--this is at best border line re: tire wear, and at the extreme of the factory spec (-0.5° +/- 0.75°). This is why your tires are worn (along with incorrect toe-in probably).[/align][/align]You can usually getthe camberto -1.0°by using a rat tail file to extend the slots outward by 1/8" to 3/16"or so, however I wouldn't make them any longer than that as you will be compromising mounting strength of the strut tower to some extent.[/align]
so im thinking of ordering from american muscle and getting
2 x 275/40/17 sumitomos
2 x 315/35/17 sumitomos
1 x J&M C/C Plates
1 x Offset Rack Bushings
$630, does that sound good?
1 x J&M C/C Plates
sound good guys?? except reg bushings not offset...i called steeda...and i think i may get the x2 balljoints too.....how hard are c/c plates to install anyone have a write up?
mungodrums
09-28-2015 10:54 PM
09-16-2015 07:53 PM
09-08-2015 11:50 AM
