Driver side window
Old Oct 13, 2007 | 02:30 PM
ColinGT's Avatar
ColinGT
Default Driver side window
On my way home from the track with my new personal best breaking into the 13s, i was riding home down I-95 and i guess i hit a bump and now my window wont go down. It makes this noise like its off the track. Then i hit it again today to show my cousin and something obviously fell off cause you heard it clank and fall down through my door haha. Do you guys think it like totally broke or could be fixed easily.
Old Oct 13, 2007 | 05:14 PM
SmallFeesh's Avatar
SmallFeesh
Default RE: Driver side window
You will have to take off the door panel to see! With out knowing what it is that fell off we can't say! Im sure it is a bitxh to mess around in the inner door panel area... most new cars are, but I have yet to see the inside of our door panels! Could be your motor fell of...lol.. or mabey a window rod or something!
Old Oct 14, 2007 | 01:08 AM
99 GT vert's Avatar
99 GT vert
it is a pain in the but to work on the inside of the door
Old Oct 14, 2007 | 06:51 AM
contentsunderpressur's Avatar
It's the window regulator. It's driven by cable and the window falls down when the cable breaks. The motor still runs but it's just spinning, not moving anything at all. The clanking noise is the cable floping around in there.
Old Oct 14, 2007 | 06:54 AM
SmallFeesh's Avatar
SmallFeesh
ORIGINAL: contentsunderpressur
I have never seen a window motor that works with a cable.... are you sure?
Old Oct 14, 2007 | 06:55 AM
I've changed hundreds of them. I get at least one or two a week.
Old Oct 14, 2007 | 06:59 AM
SmallFeesh's Avatar
SmallFeesh
I think I might actually take off my door panel tomarro to see this cable... I have changed motors in Chevy trucks, Camaros, firebirds, and hondas.... and I have never seen one that is driven by a cable!
Old Oct 14, 2007 | 07:30 AM
That's the only way to get the regulator in the door panel. The motor mounts in one spot and the regulator in another. There are two cables that go from the motor to the regulator. If they are broken you have to buy the entire regulator. I've actually never seen a regulaor in a mustang but have changed a lot in crown vics. I would assume they are the same as far as the cables go. Hopefully the window just came loose from the regulator. It could also be the plastic ***** in the motor that went bad. That's a easy cheap fix if that's what it is. Some of the older fords that has a big enough hole behind the door panel had one piece regulators but all the newer ones had cables that I dealt with.
Old Oct 14, 2007 | 07:31 AM
I'd like to know for sure what type it is though. Let me know when you take the panel off.
Old Nov 11, 2007 | 11:16 PM
ColinGT's Avatar
ColinGT
alright i havent gotten around to it myself but i will soon. the window does creep down a tiny bit, enough to leak a few drips of water if its down pouring
DreadPirateRoberts
Sep 26, 2015 02:11 PM
2k232
Sep 16, 2015 10:28 AM
movielover40
Sep 15, 2015 10:37 AM
wileec
Sep 11, 2015 10:16 AM
amandahchase
Sep 3, 2015 10:09 AM
