Smoking issue??
Smoking issue??
My '98 Gt is smoking 9 out of 10 times when i get on it decent. I rac a compression check on every cylinder. 160 to 180 psi on all 8? Are the valve guides gone and that's why it's smoking or what???? And if i need to pull the heads off is it easier to do while the engine is in or out of the car??????
RE: Smoking issue??
I had lots of puffy white smoke whenever I'd get on it, about 5-10 seconds after I started WOT...
It turns out my shifter came loose, the fluid would spill out of the top of the transmission between shifts, down to the driveshaft, which would then spatter it all over my exhaust where it would burn and smoke white out of the back of the car. Was a mess under there, looked like I killed the tailshaft seal, then followed the mess up to the shifter... where i saw my gasket blown out. Took it off, replaced the gasket with RTV sealant, threadlocker on the shifter bolts, and tightened it back down.
Check under the car... who knows.
RE: Smoking issue??
ORIGINAL: ZW99GT
How do you exactly clean that? I think that's my problem also.
ORIGINAL: oxfordgt
My buddy and wife had the same problem. Clean the pcv valve.
RE: Smoking issue??
ORIGINAL: oxfordgt
just pull the pcv valve out of the passenger side cam cover and spray carb cleaner in it.
ORIGINAL: ZW99GT
ORIGINAL: oxfordgt
