Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: How to Replace the Fuel Filter
Step by step instructions for do-it-yourself repairs
Here's how you install a fuel filter (big pics)
Ok, first, I should get a gold crown for this one! I just about went blind changing this thing out (gas in the eye isn't such a good idea). I was wearing eye protection, but the gas got through anyway. So, for those of you like me who use a jack and jack stands, put that car as high as you safely can! Get it in the air and give yourself some room to move around. I didn't have much and I certainly paid for it.
Ok, first, the filter is located on the front side of the gas tank. Stick your head under there and you'll see it.
I took one of the bolts in the bracket out first.
Then I loosened the ring around the filter. The filter was rusted in, so I just proceded with it attached. As I said, I was cramped in there and didn't have too much range of motion. I decided to keep the old filter and bracket up there and just switch the lines directly over to the new filter. The top hand line spews fuel all over the place, so be careful. (sorry, I don't have pics of this step, only the finished product after the bracket is removed)
You can see that the lines will hold the filter in there just fine. Once that second bolt came out of the bracket, it came right out.
All that's left is to put the bracket back on. Back the strap all the way out and swing it over the filter. Then you can just thread it back through and tighten it down.
One last note, take a look at these holes in the line. There are four of them going around the outside of it. Those are for the little clamps that come with the filter. Don't do what I did and try to force them into one of the holes. One arm of the clamp goes in one hole and the other arm goes in a hole next to it. It's there to clamp the hose onto the filter nozel.
I know this isn't my best write up yet, but it is the best I could do with fuel in my eye. If you need to do this, just let me know and I'll tell you whatever you need to know. It's really not that hard at all, just make sure you can move around well under the car.
RE: Here's how you install a fuel filter (big pics)
isnt there a pressure relief switch somewhere in the truck area that you press before this install to keep the fuel from spraying out? or did you do that and it was still pressurized anyway? I need to change mine...I think it has the original one in there.
lol, not yet. I'm moving down to NC in a few weeks and my time zone that I'm comfortable with installing it has come and gone. I'm going to wait until around mid December to install it, if I have found a job by then. Did you get your fuel stuff yet? What did you decide to go with?
Not bad, MAF and pump were used I take it? I'm still trying to figure out my setup. It's pretty much like yours, but I just found out you can add a Blow Off Valve on a Vortech. I love the sound those make and if I can do that, I will. It takes a special type of MAF, though. We'll see....
