fuel pump
Old Oct 29, 2007 | 04:12 PM
mhadley4's Avatar
mhadley4
Default fuel pump
Ive got a 98 Gt and i believe the fuel pumps bad. Youve got to crank and crank for it to start. Sometimes wait a couple minutes and try again. After it starts its got to run awhile to get pressure to hit the gas and the rpms jump otherwards it feels like it wants to bog down if you hit the gas from an idle. Motor is stock so what kind of fuel pump should I get?
Old Oct 29, 2007 | 04:14 PM
AJ06GT's Avatar
AJ06GT
Default RE: fuel pump
Before you go to the trouble of replacing the fuel pump. Have you tried replacing the fuel filter? All of what you described could have been caused by a clogged filter as well. That's much easier to replace and standard maintanance as well.
Old Oct 29, 2007 | 04:22 PM
incubus1275's Avatar
incubus1275
it probably is a fuel pump, but they are a bitch to replace to i would highly recomend getting it diagnosed correctly the first time...
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
