shift light
Old Nov 2, 2007 | 02:08 PM
josh.davis's Avatar
josh.davis
Default shift light
i need a shift light, but i don't need the tach... Also, i need a small one. One that can mount to the dash with velcro. I do not want to put holes in my dash.
Any info will be appreceated.
Old Nov 2, 2007 | 02:11 PM
2k1gt's Avatar
2k1gt
Default RE: shift light
http://www.raptorperformance.com/
Old Nov 2, 2007 | 02:23 PM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: josh.davis
The raptor is the only way to go. You can come up sometime and check mine out if you want. I have it mounted in the cluster, at the very top center. I mounted it with a screw, its not a very obvious one, but you could mount it with velcro if you wanted to.
Old Nov 2, 2007 | 02:40 PM
josh.davis's Avatar
josh.davis
Will it tie into my factory tach? Also, how much are they.
Old Nov 2, 2007 | 02:46 PM
2000GT4.6's Avatar
2000GT4.6
Its around 100 bucks, you can order it from the link that 2k1gt gave you, that is www.raptorperformance.com
You run the wire down to the ECU in the passgenger side kick panel, and then hook it up to GND, +12v, and one of the COP wires that comes out of the ECU. The raptor page has instructions on what wire to use, its pretty easy to install.
I just pulled my cluster bezel out, snaked a straigtened coat hanger over to the passgeger side, and pulled the wire thru. The hardest part was taking apart all that plastic crap over the ECU housing, getting it out, and getting it back in with all the bolts intact. Its a straightforward and easy install.
The raptor has switches so you can set the RPM you want it to come on at etc.. really its the sweetest "all in one" shift light out there.
Old Nov 2, 2007 | 03:14 PM
josh.davis's Avatar
josh.davis
thanx
Old Nov 2, 2007 | 04:09 PM
96gtchinook's Avatar
96gtchinook
http://cgi.ebay.com/ebaymotors/ws/eB...66619&rd=1
maybe try this one??? looks like decent quality, any other input on this?
Old Nov 2, 2007 | 04:33 PM
2k1gt's Avatar
2k1gt
He wanted something small. That thing is HUGE
Old Nov 2, 2007 | 06:18 PM
5speedstang's Avatar
5speedstang
ORIGINAL: 2000GT4.6
i thought the hardest part was getting that dam headlight **** off.
i just put mine is a month ago and i love it. perfect during the day and very nice at night. lights up my whole car. it looks bad ***.
here is a vid and a pic
http://s158.photobucket.com/albums/t...t=MVI_0208.flv
the only thing it blocks is the high beam indicator. you can see both blinkers perfect.
degner122
Sep 16, 2015 07:09 AM
Colin Ringle
Sep 15, 2015 09:27 PM
Mustangmalo
Sep 6, 2015 05:22 PM
amandahchase
Sep 3, 2015 10:09 AM
