Cam question??
Old Nov 15, 2007 | 12:21 AM
TayGt's Avatar
TayGt
Default Cam question??
I want to supercharge my stang eventually? so my quest is if i get the blower cams and put them in now will it hurtmy performance untill it is supercharged?
Old Nov 15, 2007 | 12:26 AM
ZW99GT's Avatar
ZW99GT
Default RE: Cam question??
It won't hurt one single bit. You will see decent gains with blower cams, but not as much as an aggressive N/A cam.
Once you get that blower on, you'll be glad you did some good research/planning, instead of just throwing something in there for the moment. Call VT or COMP and talk with them about grinding you a set of blower cams. They aren't much more expensive than something off the shelf, and they can make you a specific cam according to your plans and power levels.
Old Nov 15, 2007 | 12:36 AM
TayGt's Avatar
TayGt
wow thanks for the help zw99gt
Old Nov 15, 2007 | 12:39 AM
2000GT4.6's Avatar
2000GT4.6
Your definatly not going to see big gains with blower cams on a n/a car though. Your looking ata cam with far less overlap and a shorter intake duration than a n/a cam. Less overlap + small intake duration + big exhuast duration isn't the best setup for a n/a car.
Old Nov 15, 2007 | 12:43 AM
TayGt's Avatar
TayGt
Well i wanted to get the lop noise first with heads and cams then later on get the blower.
Luke9222
Oct 22, 2015 11:55 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
