90 mas
Old Nov 19, 2007 | 11:36 AM
josh.davis's Avatar
josh.davis
Default 90 mas
I bought a 90 mass air flow senor that used to be on a lighting. My question is can i just bolt it in, our what kind of tuning do i need to get done?
Old Nov 19, 2007 | 01:19 PM
4.6LPoppy's Avatar
4.6LPoppy
Default RE: 90 mas
I just bolted mine on and it worked fine. If you get a dynotune the tuner can tell you its range and set the A/F appropriately.
Old Nov 19, 2007 | 03:56 PM
oxfordgt's Avatar
oxfordgt
Default RE: 90 mas
Why did you waste your money on that? Are you installing a supercharger? If not it wont do anything for you and you will need a tune.
Old Nov 19, 2007 | 04:21 PM
arcticman37's Avatar
arcticman37
Default RE: 90 mas
ORIGINAL: oxfordgt
EXACTLY
Old Nov 19, 2007 | 04:35 PM
josh.davis's Avatar
josh.davis
Default RE: 90 mas
yeah i plan on getting a supercharger eventually.......... i got it for fifty bucks,and it is listed in jegs for like $180.
So its no use untill i supercharge my car.
Old Nov 19, 2007 | 04:38 PM
oxfordgt's Avatar
oxfordgt
Default RE: 90 mas
It is a supporting mod not a power mod. It is made for 30lbs injectors and your car has 19lbs. You will need a tune ($300-$500) to keep your car running right or it will run lean. Put it on the shelf and save it till you buy a supercharger.
Old Nov 19, 2007 | 05:12 PM
josh.davis's Avatar
josh.davis
Default RE: 90 mas
[sm=goodidea.gif]
Dathan
Oct 5, 2015 05:52 AM
ibeeskeef
Nov 17, 2005 07:48 PM
95Stealth302
Aug 19, 2004 05:04 PM
RedStangGT2000
Aug 7, 2004 08:48 AM
