Sea Foam?
RE: Sea Foam?
These are the "Common Reasons Technicians use SEAFOAM..." from their website--all of them generally the result of very poor maintenance and/or extremely high mileage.[/align][/align]Which of these problems are you experiencing? If none of the above then keep thatcrap away from your car as it will at best do nothing, and at worst screw something up. [/align][/align]Seafoam was developed back in the 1930s for use in marine engines that typically run cold and often sit unused for months during the winter (hence the product's name). Under those running and storage conditions, and with the lesser quality fuels and lubricants of those days,it was common for carburetors and intake valves to fill up with all sorts of crap--pouring a mixture of kerosene and more volatile solvents into the intake would very often dissolve the crap and make the motor run better.[/align][/align]Properly maintained modern automobile engines, using modern lubricants and fuel, do not need this sort of "mechanic-in-a-can" snake-oil--ever. We generally run our cars up to 200k to 300k miles (I had 325k on my '90 Miata, the last 100k supercharged) and I have never had any need for Seafoam or any other of the magic potions you'll see on the shelf at your FLAPS...[/align][/align]
RE: Sea Foam?
ORIGINAL: 6mustang6
haha. yeah switching to a synthetic oil in high mileage engines is a no no. i have to tell people this all the time.
seafoam combined with WOT acceleration does do the motor good, its best to start at 50-75k and then do it every 15k afterwards
RE: Sea Foam?
ORIGINAL: Spring00gt
Why is switching to synthetic oil so bad for your engine?
Synthetic is thinner, and made to clean out sludge. Once the sludge is removed from these old seals, leaks usually, not always, will begin to appear.
yourmom6990
09-14-2015 10:52 PM
