Need help diagnosing an on going problem
RE: Need help diagnosing an on going problem
ORIGINAL: FDNYBullitt
If you take off the fuel rail with the injectors still in it and turn on the key, it willleak alright,all 4 injectors are gonna fly across the room because theres nothing to hold them in place, so lets not try that one, good luck.
well the white smoke went away now, must have been alot of condensation or something....my coolant and oil is fine....the mechanic said me having to add a quart of oil is fine since its been about a 1.5 month since i changed it.....i checked hte injectors and only one was spraying right....the others are all clogged and just dripping so this is def. the cause of my horrible gas mileage.....im giving fuel injector cleaner a shot to see if that works....otherwise how much would new injectors cost?
jessicarabbit
09-25-2015 12:41 PM
stangin1996gt
09-21-2015 11:01 AM
