Relieving fuel system pressure
Relieving fuel system pressure.... Friend of mine did it under the hood through a schraeder type thing. Read maunals and the procedure ranges from a vacuum suction in line with a fuel line to disconnecting the inertia switch in the trunk and starting the engine...nothing about schraeder valves. 1998 SVT Mustand Cobra.
Thanks
Ian
Thanks
Ian
RE: Relieving fuel system pressure
I just pull the fuel rail off and clean up afterwards. Not the recommended method but I have an 04 with no shrader valve and not gonna wait the 10 min it will take for the line to run out of fuel with the inertia switch triggered.
What are you doing that you need to relieve pressure?
09-10-2015 08:39 PM
09-08-2015 11:50 AM
