need some info on block......
ok so im ordering a new romeo block, and i just had a few questions, im eventually going to also buy a balanced rotating assembly from modularperformance.net in standard bore, and was wondering if id have to take the new block in for any machine work or if i could just start assembling. thanks in advance.
RE: need some info on block......
You might need to have the cylinders honed. The stock pistons run a tight piston/wall clearance. Forged aluminum pistons require a slightly looser bore. You're really just going to have to measure the bores for diameter and roundness to be sure.
so should i take it to a machine shop (arnolds motor supply) and let them check and rehone it or would it be just as easy to buy a short block, anybody have any good expiernces with MMR or any good refrences, maybe ill just use the search button lol.
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
junior04
09-28-2015 10:53 AM
