Best Oil for Higher Milege mustangs!!!
Old Dec 8, 2007 | 12:35 AM
KillaGT's Avatar
KillaGT
Default RE: Best Oil for Higher Milege mustangs!!!
I LOVE USING PENNZOILS WITH LUCAS !!, my car is 134k miles and been using pennzoils 10w/30 with lucas oils and it turn out to be best oils I had use. Stick with what work.
Old Dec 8, 2007 | 01:00 AM
effingroovin647's Avatar
effingroovin647
109k mobil1
Old Dec 8, 2007 | 01:05 AM
fiad06's Avatar
fiad06
43k kendall GT1
Old Dec 8, 2007 | 01:16 AM
GhostRider02GT's Avatar
GhostRider02GT
ORIGINAL: GrayGhost01GT
are all convetional oils wax based i mean my motor can see 160k out of using this oil right?
I dunno, just I heard forever from many people in the lube industry that pennzoil is crap and parafin based oil. Sure, itll last you a long time, but pull the motor apart, there will be crap and sludge EVERYWHERE, and lucas and pennzoil isnt as bad b/c lucas is good stuff
Old Dec 8, 2007 | 01:23 AM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: POISND U
Until an unbiased, unsponsored, scientifically controlled series of tests are done and published there is one answer:
Any synthetic.
The only constant should be that you stick with the brand you choose.
+1
Synthetic is just worlds above anything else out there. "high milage" oils generally are nothing more than a thicker oil to stop leakage, and mostly even then they are snake oil.
You don't have to worry about leaks and worn seals for a LONG time in a 4.6L if you use synthetic from the start and stop that wear. My car will never see anything but synthetic ever again, regardless of milage.
Old Dec 10, 2007 | 12:36 PM
hack_239's Avatar
hack_239
^+1
45k and on it's 2nd batch of RP 5W-20. I used Mobil-1 5W-20 before that. It hasn't seen anything else other than what the dealership used in the oil changes I had them perform prior to 20k.
I also don't know if it is wise but the RP website recommends waiting 12k between changes when using their product. I think they even guarantee the motor if a failure is proven as a result of their oil.
Old Dec 10, 2007 | 12:41 PM
mvr's Avatar
mvr
ORIGINAL: hack_239
it'll go 12k before you need to change it
but there is nothing wrong with chaninging it our for clean oil every 3-5k.
Old Dec 10, 2007 | 04:16 PM
E_LOW's Avatar
E_LOW
what about using motorcraft 5w-20 symthetic blend?
Old Dec 10, 2007 | 04:50 PM
GhostRider02GT
synthetic blend? why bother...
Old Dec 10, 2007 | 05:00 PM
True Blue Racing's Avatar
True Blue Racing
i have 142k on mine i use quakerstate 5w-20 with lucas
