SOOOO SQUEEKY
Old Dec 8, 2007 | 12:31 PM
beastzilla02's Avatar
beastzilla02
Default SOOOO SQUEEKY
so everytime i hit my brakes i hear a squeek. it might be from my rim cleaner because my brake discs have some spots of green due to it..can this cause that? and if so how do i clean my brake discs....anyone?
Old Dec 8, 2007 | 02:45 PM
GrayGhost01GT's Avatar
GrayGhost01GT
Default RE: SOOOO SQUEEKY
just keep driving and braking, and see if it dont stop, and if it keeps up you might need you brakes re surfaced
Old Dec 8, 2007 | 08:15 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
Brake squeek is normal on disc brakes. It'll eventually go away. Unless it's a bent backing plate or semi metallic flakes contacting the rotor. Just keep driving it and see if it goes away. If not, you'll have to pull the wheels and take a look.
Old Dec 8, 2007 | 08:16 PM
Flake6899's Avatar
Flake6899
When was the last time you got brake pads?
Old Dec 9, 2007 | 12:18 AM
Chubstang's Avatar
Chubstang
my guess is that the pads are vibrating against the caliper causing a squeek. You could try pulling the pads off and putting a little Disc Brake Quiet where the back of the pads contact the pistons.
Does the squeek go away when you press on the brakes hard?
Johno29
Aug 21, 2015 06:21 AM
SPARTAN VI
Jan 27, 2006 10:34 PM
Warrior094
Jan 11, 2006 05:47 PM
