help fast!
Old Dec 14, 2007 | 11:40 AM
cisurfer's Avatar
cisurfer
Default help fast!
well i was taking off my front driver side tire and on of the studs is turning, i guess it isnt pressed on in the back anymore and i cant get the damn lug off, the stud didnt snap i can feel the back of it turning and i dont know what i can do to get it off...please help i have work tomrrow!
Old Dec 14, 2007 | 11:41 AM
1fstblckgt's Avatar
1fstblckgt
I ♥ Acer
Default RE: help fast!
EDIT: nevermind.
Old Dec 14, 2007 | 11:42 AM
Xemeth's Avatar
Xemeth
First try tightening the lug nut again, and possibly pull the stud through back to where it's supposed to be. Just for a temp fix at least.
If not, cut it off with a die grinder or something and install a new stud.
Old Dec 14, 2007 | 02:43 PM
cisurfer's Avatar
cisurfer
cant do either, if i try to tighten it the stud spins also...i cant get access to it to cut it, if anything ill have to break the nut thru the wheel with something
Old Dec 14, 2007 | 06:48 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
You're going to have to cut the lug off or get an impact and tighten down the lug and it should pull the stud back in.
Old Dec 14, 2007 | 07:26 PM
03greyGT's Avatar
03greyGT
might need to zip it with an impact....it should turn the lug faster than the stud can turn...
Old Dec 14, 2007 | 08:37 PM
Sxynerd's Avatar
Sxynerd
BFH and a chizel... WEDGE in from behind and muscle that MF... I've done it... 80% of the time it works everytime!
Old Dec 14, 2007 | 09:20 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
ORIGINAL: sxynerd
"It works 80% of the time, all the time."
"That doesn't make any sense."
Old Dec 15, 2007 | 01:55 AM
cisurfer's Avatar
cisurfer
haha well what i did was drill the stud out from inside the lug then put a chisel in it wacked it a couple times and came out
Bokeo
Oct 10, 2015 08:28 PM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
ctgreddy
Sep 20, 2015 08:35 PM
Sep 16, 2015 07:53 PM
