Solid engine mount guys..
ORIGINAL: oxfordgt
Hope you are ready to go thru the car once a month and tighten loose bolts. Solid mounts are race parts only not DD. I have poly urethane mounts and have had to tighten some loose bolts. My buddy has solid on the motor and tranny and its very uncomfortable to drive. Cant use the mirrors, the steering wheel shakes alot, the seats vibrate loose they are just more of a pain then they are worth.
Solid mounts do suck, but at last... there is an alternitaive!!!!
3M Window-Weld!!!!
You simply fill in your motor mounts and it works GREAT!!!!
You get all the benifits of solid mounts but none of the headaches!!!!
3M Window-Weld!!!!
Nov 10, 2015 11:39 AM
