Speed release or Triple hook???
RE: Speed release or Triple hook???
ORIGINAL: cliffyk
The "teeth" have nothing to do with holding the cable, they are entirely related to the ratcheted adjustment mechanism. All of the plastic stuff (including the OEM adjuster) is removed and the new quadrant is mounted to both fixed pins on the pedal--the OEM quadrant pin and the ratchet pin. The "hooks", one on the speed release and 3 on the triple-hook, hold the cable end.[/align][/align]The UPR speed release quadrant requires an adjustable cable and optionally a firewall adjuster, the triple-hook quadrant requires a firewall adjuster (I have the 3-hook and UPRs Quick-click adjuster), and will work with the OEM cable. I have read a number of tales of aftermarket clutch cables being of lesser quality, don't know if this is true however my car is my DD and I don't need that sort of problem cropping up 200 miles from home.[/align]
Not true as I have the UPR quick click adjuster with the UPR speed release quadrant with OEM cable and it work like it is supposed to. An "optional" firewall adjuster with an OEM cable...Sorry that a requirement unless you use an adjustable cable.
ORIGINAL: fyouceeku
ORIGINAL: cliffyk
Yes we do have a retail store in Lake Worth. The hours are M-F 8-6 Sat 9-1 The factory cable must be used with a triple hook quadrant and a firewall adjuster.
Call 561 588 6630 and ask for Pat.
Thank you,
Thank you,
Which I interpreted as meaning an adjustable cable was needed with thespeed release...[/align][/align]I've never seen one, and obviously a number of folks have used the combination. so I will certainly take eveyone's word that it does work...[/align][/align]I also never said the adjuster was optional with the OEM cable (read it again)--I said it was optional if you used an adjustable cable...[/align]
ORIGINAL: lizzyfan
He did!
ORIGINAL: JayC
Use washers on the pivot points?
ORIGINAL: lizzyfan
It's perfectly adjusted
ORIGINAL: JayC
if it's rattling it's not adjusted right[8D]
deffinately go with the fire wall adjuster. i didnt and it sucks when ever i need to adjust my clutch i have to crawl underneath and try to turn the nut which is right by the clutch fork.
BeatnikFink
10-01-2015 08:00 PM
