will this spot work for hood pin install?
RE: will this spot work for hood pin install?
ORIGINAL: Novanutcase
Just drill out the stops and run them through the pins so that your hood sits on top of them so that it sits right!
John
John
Lynn
Measure them, but see what happens first after you got the pins in, you may not need to do that...
When you adjust your pins, they need to be pull the hood down so it won't come up at all.
You may not need them as the side fender hood stops will keep the sides from coming down, and the hood pins and latch will keep it from coming up thus keeping it where it needs to be. Atleast that was how it was with every car I had with hood pins.
Lynn
Lynn
i pulled the stops out and closed it without any stops and the whole hood sits in low...idk what you mean by side stops, but the sides will sink....ill just install the pins and then figure out what to do about the height....
ORIGINAL: 99BlackPonyGT
You can see it right above the air box on the inside fender.
Lynn
yea....i really dont think i have those......ill have to look in the morning.....in fact im pretty sure i dont, because without the front stops, my hood was sitting down in...like the fender was taller than the hood...like this \____________/ the hood sat down in.....if i dont have them ill pick some up
BTW.....why do you have to weld the nut in? Can't you just thread a nut under the radiator support where the stop was before and thread a nut on top and tighten? I have an '03 GT so it may be different butmine has a square hole where the stops go. I'm about to install some hood pins so I'm thinking that if I just run a fender washer and nut under the the top of the radiator support and one on top and tighten it dwon it should be fine. It's not like there will be a bunch of stresses put on that area anyways!
John
John
John
John
Lynn
John
John
http://www.modularpowerhouse.com/for...ight=hood+pins
Lynn
