need h-pipe advice
RE: need h-pipe advice
weinstall pacesetter exhausts here and thereat my work and they never seem to fit quite right, granted the cars are all like 30-40 years old. I'd say just get a summit h, you can get one brand new for around $100 or so and I've never heard anything bad about them.
You'll also need to install a Fix for the Sensor's .
The sensor's after the cat, an easy fix is to buy some spark plug non fowlers.(auto parts store)
Take 2 of them and drill a hole big enough to fit the Sensor into.(there is a hole already in them but you hav eto open it up)
Then screw the 2 rear Sensor's into thethe Drilled parts, Then Screw them into another Spark Plug non Fowler, making an extension like part. ( Don't Drill out the Bottom Fowler the hole in it is what you want.) this takes 4 fowler parts, 2 that R drilled out for Sensor to fit, and 2 for EXTENSION. This will take the Sensors out of the Pipe for a Bypass like Fake out! WORK IN BOTH MY MUSTANGS!!!
Hope this helps!
Hope this helps!
09-24-2015 09:18 PM
