ZEX vs. MSD (window switch)
Old Dec 31, 2007 | 09:18 AM
pigmie's Avatar
pigmie
Default ZEX vs. MSD (window switch)
I bought the ZEX .
But here's waht I think now.
The ZEX has Wires coming right out the Front???? What BOZO came up with that???
MSD is $50 Bucks Cheeper ( Dam Was I the FOOL!!! ) I could have mounted this on my dash!!!
I bought The ZEX Nitrous Wet System ( LOVE IT....BEST ) going to use 100 shot !!!
Also bought MACHINE GUN PURGE KIT!!! ( O.K. Now I'm Broke! )
But the ZEX window switch ( S u C k S!!!) Still looking for the right TACH wire!!!
MERRY CHRISTMAS EVERYONE, And Have a SAFE NEW YEAR!!!!
Old Dec 31, 2007 | 10:24 AM
01GT4.6's Avatar
01GT4.6
Default RE: ZEX vs. MSD (window switch)
I installed my digital MSD the other day and it was a snap. Is the Zex one set up for 1 cylinder operation. did you want to tap into the tach signal inside the car or under the hood? Let me know and I'll point you in the right direction. I mounted my MSD in my glove box and tapped my tach signal, power, and ground all in the car under the glove box in the passenger side kick panel. I only had to run 1 wire out.
Oh yeah... NX > ZEX
Old Dec 31, 2007 | 10:33 AM
SpecterGT260's Avatar
SpecterGT260
the tach wire was a bitch for me (i used msd tho but im guessing they use the same tach system). Im pretty sure I did single cyl. However you will not get the tach to work right unless you use a relay. If you want I have some self made schematics around here for wiring.
Old Dec 31, 2007 | 11:13 AM
wwmost's Avatar
wwmost
its a good thing you got the zex window switch with the zex kit man. i had a bitch using my msd window switch with my zex nitrous kit. this is because the zex nitrous kits and the zex window switchuse the tps of the nitrous kit to turn the kit on and off and the msd window switch uses the ground to turn the kits on and off. when i used the msd switch, it made my zex box go crazy every time it took away its ground. the zex nitrous box needs to have a constant ground for some reason. the way i fixed this is i put a wot switch with my zex wot switch together. the zex system usually uses your tps sensor as a wot switch but i used both. i know this sounds confusing but i was trying to fix this problem for a month. and finally fixed it. my idle would raise up and down with the zex sysems ground taken away and the power still hooked up. it had to do somthing with the tps wire. soo all in all if i were to do it again i would get the zex window switch. it hooks right up to the tps wire and control the nitrous system by giving and taking away the tps wire voltage.
haha thats the best way i can explain it. im still confused about this thing.
Old Dec 31, 2007 | 03:04 PM
pigmie's Avatar
pigmie
[8D]Here's the Right fix Pin #48 on PCM (ECM) Orange/white Wire.
Works Fine now!
wwmost after reading your post, GLAD I bought the Zex Window switch!!!
Just had to find the right Tach wire.
Thanks for all the Info!!!
[:-]HAPPY NEWYEAR!!!!
Old Dec 31, 2007 | 03:18 PM
pigmie's Avatar
pigmie
o1GT4.6 Thanks for your help.
I tapped into the Passenger kick panel, Pin #48 Orange/white wire is TACH wire.
SpecterGT260, Thanks for your info.
Hooked up Rapid Fire Dual Purge also, Had 2 Blue Lights BUT left them off .(hole was only big enough for Purge pipe!, Maybe later)
Last thing , need to FILL THE BOTTLE!!!!!! WHHHHHHHAAAAAAAAAAAAAAAAAAAAA
HAPPY NEWYEAR!!!
Old Dec 31, 2007 | 03:31 PM
01GT4.6's Avatar
01GT4.6
you're welcome, happy new year to you to
Old Dec 31, 2007 | 04:23 PM
ZW99GT's Avatar
ZW99GT
I have the ZEX swtich on mine. Worked fine with my NX system.
Old Dec 31, 2007 | 06:35 PM
dsbsurfn's Avatar
dsbsurfn
I use the Zex switch and an MSD GRM pickup. The pickup goes around the positive (red) wire on the individual coil. no need to tap into anything! It was a bit more expensive, but totaly worth it.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
firehorse02
Nov 16, 2015 11:28 AM
guitarman376
Sep 30, 2015 05:54 PM
