stock cam specs?
stock cam specs?
i've done some searching around and can't seem to find anything solid, but i'm looking for the stock cam specs for my '02 GT. if anyone has a link i'd really appreciate it.
also, i'm looking at the VT stage 2 n/a cams. are there any piston-to-valve clearance issues with these with stock pistons?
RE: stock cam specs?
Lift:.535 intake / .505 exhaust. 192/184 duration @.050
Vt stage 2's should work with no clearance issues.(by the way they are not made by VT anymore ,it is cushman motorsports now.)
ok thanks. i'm probably going to do a cam swap sometime in the next month or so, and from what i've read on here people seem to favor the VT cams. i found them on Cushman Motorsports and they're reasonably priced.
when i do the cam swap, will i need to replace the cam followers too, or can i re-use the stock ones? any other advice on the cam swap? i've built plenty of pushrod motors, but i'm new to the cam setup on the modular engine so any advice is appreciated.
uberstang1
09-20-2015 06:42 PM
