Got a Doozie for ya, codes, hesitation, fun!
RE: Got a Doozie for ya, codes, hesitation, fun!
ORIGINAL: cliffyk
Here are links to the troubleshooting tips for P0132 and P1132 from the shop manual...[/align][/align]P0132, P1132 (same tips as P1130),they both point to a bad or incorrectly wired front passenger side O2 sensor.[/align][/align]P0008 is a generic DTC indicating a problem on bank 1 (most likely the O2 sensor as indicated above);[/align][/align]P0000 is a generic DTC meaning "no diagnostic codes present" -- what tool did you use to get the codes?[/align][/align]B0000 is a generic code as well (any codes with "0" as the1st numberare) and seems to point to a bad speed monitoring circuit...[/align][/align][/align][/align]
and when I used my MAC diagnostic scan tool it only showed the p0132 and p1132, could it be MAF or would it more than likely be the 02 sensor? I was thinking that if it was the MAF, then wouldnt both bank 02s be reading incorrectly, not just one?
Sounds like its misfiring. Sounds like you checked all hardware too... you got spark and fuel? Does your exhaust smell, it probably will if it misfires. If so, then i believe its the PCM hesitation problem, where its just lean enough to misfire. I got mine fixed with a $80 reflash to new calibration at the dealer.
Your MAF shouldnt need cleaning, like ever, i think. Its in some very clean air.
ORIGINAL: GhostRider02GT
I got those codes from my little scan gauge
ORIGINAL: cliffyk
thanks, could it be the LTs and the tune though??
The 'B' code is a body controller. I would reclean your MAF because if there is a light film over the fillament it will cause stumbling. If the problem consist check your 02's.
ok tomorrow I am gonna get some electrical cleaner and clean the MAF, along with replace Bank1 sensor 1 02 sensor. Which is Bank 1, driver side or passenger side??
also, new code tonight after stalling again after a 40 minute drive to class,
P1018 ?
P1018 ?
Bank 1 is the passenger's side...[/align][/align]P1018 is not listed in any source I have as a Ford specific code (all P1xxx codes are manufacturer specific)--I did find it on a Chrysler list as a "serial data circuit" indicator (but you knew that as you were told in December).[/align][/align]It could be that your tune and/or PCM are scrambled...[/align][/align][/align][/align]
yea that p1018 code throws me off b/c only my retarded little scan guage reads that, my MAC tools scanner only reads the 0132 and 1132, I am replacing the 02 sensor and if that doesnt work, Ill take it to my tuner
configured the pcv system back to stocker, got some CFC MAF cleaner, and swapped 02 sensor, cleared the codes, so far so good. The 02 sensor was filthy and I can tell when the guy did my trans and reinstalled my pass header pluged the 02 sensor in, then screwed it into the bung b/c the wires were all twisted
1, bank, code, diagnostic, dtc, edge, engine, juice, module, mustang, p0008, performance, position, system, troubleshooting
