do i need bigger injectors.
RE: do i need bigger injectors.
ORIGINAL: 1SLO85
ninelives...what are your car specs for 330rwhp N/A?
ORIGINAL: ninelives19821
+1 the wet kit will give the motor the fuel it needs instead of you depending on your injectors to make the increase. If your only running a 50 shot it may not be a issue but wet kits for sure give you piece of mind knowing it will make sure you have enough gas and not maxing out your stock injectors. I would upgrade the fuel pump though
ORIGINAL: 2000GT4.6
Don't screw around with the dry kit, just get a good wet kit and be done with it.
ORIGINAL: 01GT4.6
I was thinking the same thing.
ORIGINAL: 1SLO85
ORIGINAL: 2000GT4.6
