PI cams or Headers?
PI cams or Headers?
Hey I have a friend with a 98gt and he was wondering which would be more worth it
PI cams? (can get them for around 60 used)
or LT headers? (can get a set for around 400)
for the price including install.
RE: PI cams or Headers?
buy LT..........then call MPH for custom blower cams. Also, look into the mongoose kit. alot of people have had good luck with it.
http://modularpowerhouse.com/product...738db9141c9001
I would do a full PI swap before I did headers. Probably not gonna see any gains with headers on a NPI engine.
If he's getting a supercharger then PI intake and cams, since swapping the heads will result in a little too much compression for an aggressive s/c setup.
The NPI's respond better than the PI's from long tubes.
You should check out this book
http://cgi.ebay.com/ebaymotors/Build...3286.m20.l1116
Tons of before and after dyno tests on EVERYTHING for the 4.6 motors.
EDIT:Your friend, not you, should check out the book. I just realized you weren't the one with the 98, heh. It's definately worth the cash.
junior04
09-28-2015 10:53 AM
JDWalton
09-24-2015 08:47 PM
