Starter Removal
What all is involved in removing the starter? I see the one bolt on the bottom, and then obviously the wires going to it. What else?
My uncle tried to do me a favor by installing m x-pipe for me. He ended up stripping the bolt on the passenger manifold stud right next to the starter. Now I'm going to have to cutthe nutoff to get the stock h-pipe off...
there are three bolts and the wires you can see. bolt one you have found, bolt two is just on the otherside of the starter solinoid, and the last is only possible if you have small hands. its directly above the first bolt and easiest to access from the front of the vehicle. using about 18" to 24" of extensions, slipping it over the k-member just beyond the sway bar, work its way back to the bolt.
jwog666
Dec 27, 2021 08:09 PM
logan409
Sep 26, 2015 07:43 PM
