New engine wont turn over
Old Feb 22, 2008 | 01:06 AM
fruhdaddy's Avatar
fruhdaddy
Default RE: New engine wont turn over
well it wont turn over in neutral first. second what is the differance between flywheel and flexplate? should I take the timing cover off first to check out the chains and tensioners making sure they are aligned and not off track?
Old Feb 22, 2008 | 08:42 PM
racer02GTstang's Avatar
racer02GTstang
a flywheel is whats in a manuals and the clutch bolts to, autos have flex plates which the torque conver bolts to. the look different in most cars as well... a flywheel has the teeth on it and in most cars the torque converter will have the teeth so there is a way to tell... sounds like the torque converter is pushed into the tranny to far possibly. i would put that spacer in there for sure and then go from there. that could fix the problem in itself.
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
drumhedd2005
Aug 13, 2015 09:59 AM
yurizx6r
Aug 11, 2015 07:50 AM
