Finding tach wire
Old Mar 10, 2008 | 11:14 PM
igotit4cheap0023's Avatar
igotit4cheap0023
Default Finding tach wire
I just installed a MSD digital window switch and have everything wired up except for the tach wire. Does anybody know what wire I could tap into and where exactly where it is located.
Old Mar 10, 2008 | 11:36 PM
99black5spd's Avatar
99black5spd
Default RE: Finding tach wire
yes you could use the negative wire on anyone of the coil harness'....one more question...did you use a relay?..cuz you need one...i actually just finished my nitrous install so if you have n e questions just ask....
steve
Old Mar 11, 2008 | 12:07 AM
igotit4cheap0023
I did use a relay it goes to the WOT switch and the FPSS. My window switch goes to the other side of the FPSS. Does your car have COP's? Did you have the digital window switch? If so do you have to change it to a 1 Cyl since its has COP's? Lots of questions I know but I need help. Thanks
Old Mar 11, 2008 | 10:45 AM
igotit4cheap0023
I found the wire under the passenger side kick panel. Here is a picture of it hopefully this will help somebody else who is having this problem.
http://www.raptorperformance.com/For...p;%20wires.jpg
mtgldr
Feb 3, 2024 09:00 PM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
