maybe someone could help with suspension
Old 03-31-2008, 04:12 PM
cisurfer
cisurfer's Avatar
Default maybe someone could help with suspension
ok so i have the eibach prokit, dubarado also has it and his front sits a little lower than mine does, atleast by the looks of it, i want that raked look...i read about 4cyl fox springs but the handling sucks...what about leaving the eibachs up front and putting the stock rears back in?
cisurfer is offline
Old 03-31-2008, 04:28 PM
baino
baino's Avatar
Default RE: maybe someone could help with suspension
you could try taking the rubber bushings off the front springs, it will give a subtle drop. I think that stock in the rear and eibach up front would be too much contrast and not look that good. just my .02
baino is offline
Old 03-31-2008, 04:30 PM
cisurfer
cisurfer's Avatar
yea i took out the bottom isolators and put a vinyl hose around it instead, doesnt look like it did much...and every bump is terrible with the eibachs int he rear feels like my car is gunna fall apart
cisurfer is offline
Old 03-31-2008, 04:35 PM
jmac72187
corner carver
jmac72187's Avatar
Ride quality will have more to do with your shocks/struts being matched with your springs.
You might just have to pick up a new set of springs.
jmac72187 is offline
Old 03-31-2008, 05:15 PM
baino
baino's Avatar
guess my IRS is just that much different. It rides like a dream with the prokit
baino is offline
Old 03-31-2008, 05:18 PM
jmac72187
corner carver
jmac72187's Avatar
ORIGINAL: baino
IRS just drive smoother in general.
Old 03-31-2008, 05:20 PM
fobra570
fobra570's Avatar
ORIGINAL: cisurfer
did u put the new bump stop on the kmember?
fobra570 is offline
Old 03-31-2008, 06:07 PM
2000GT4.6
2000GT4.6's Avatar
ORIGINAL: cisurfer
I did not notice a big handling difference with the fox 4cyl springs, but I am running adj shocks/struts/
2000GT4.6 is offline
Old 03-31-2008, 07:29 PM
cisurfer
cisurfer's Avatar
new bump stop on the k member? it came with one for the rear?
cisurfer is offline
Old 03-31-2008, 08:11 PM
Jbauer
Jbauer's Avatar
Stang suspension sells HR super Sports sepratley..what i would do, i would keep the pro kit in the rear, and drop HR SS in the front with out any isolators. Sportlines would be a better choice if you can find the fronts seperate.
Jbauer is offline
baddog671
07-26-2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: maybe someone could help with suspension
