Valve Springs!!
Valve Springs!!
Hey whats up everyone
well heres my question...will these valve springs work with my stock retainters and everything or will i need to buy some different ones
http://store.summitracing.com/partdetail.asp?part=CCA-26113-16
and also...these springs are good for cams that have a .550 lift right or does the spring need to be able to hold more than a .550 lift??
or would this set-up be better
https://www.patriot-performance.com/xcart/product.php?productid=86&cat=63&page=1
2010 Blue Ball Award Recipient
RE: Valve Springs!!
Sorry I dont have an answer, but THANK YOU for deciding to replace the valve springs with your stage II or higher cams...
i recall the post the other day about 'doing it even though some people said not to'
RE: Valve Springs!!
The Comp 26113-16 will work with your stock retainers. I also have them on sale this month..less than Summit. Those Comp springs are "rated" at .550" lift, but they are under-rated. They can be used for close to .600" without issue. I use them all the time with my Stage 2 n/a and they are .575" lift.
RE: Valve Springs!!
ORIGINAL: josh.davis
Looks like you updated your web page.looks good[sm=goodidea.gif]
MT-Drag radials-xcal 2- B/M short throw shifter.
All that bark.....but no bite! [sm=laughat.gif]
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
