vapor leak
RE: vapor leak
Evap and vacuum leaks are seperate problems...
If you have a vac leak, you'll throw lean codes..and possibly run like crap if its a bad enough leak..But you should be able to hear the leak if its that bad. You could have a bad spark plug causing it to miss
bradleyb
11-27-2015 07:50 PM
