Got the 4.10s on...
RE: Got the 4.10s on...
check out this site. I didn't know about the break in period either so I looked it up. http://www.ringpinion.com/content/te...lt.asp?pid=122 It pretty much says that if you don't break in your new gears right you could potentially cause lots of damage. It also recommends to change the oil after 500 miles on the new gears. I hope this helps.
I'd get those gears looked at again. The gears should be whisper quiet at all speeds. Did he change the bearings out when he put the gears in? If so, he may not have shimmed it properly and it's the gears making the noise. Is it a whining noise or a rumbling noise? Either way, if you can hear it over your exhaust, it's no good.
-Daniel
-Daniel
ORIGINAL: djlittle21
-Daniel
-Daniel
Kind of off topic, but how much hp does a Stage II Rousch come stock, one of the newer years.
junior04
09-28-2015 10:53 AM
Figure8allday
08-22-2015 11:11 AM
