2004 mach system wire colors?
Ok well i tried adding an amp and sub to my stock mach system in my '04 gt and i used to a line out converter from the wires i spliced into from the mach system. I followed the guide from mustang w*rld and i was under the impression that all the wire colors are the same in the guide but i contacted the guide maker and he told me every year has different color wires. So i obviously tapped into the wrong colors since his guide was from like a 1998. So i have been doing everything to get my sub and amp to get a signal thinking it was on my end with hte amp and sub but apparently its the wires. Can someone who has tapped into the mach system wires on a 2004 tell me what colors they tapped into? I tapped into the data cable wires and followed it this way: "What you need to do is splice into the following wires (2) black wires with white stripes and (2) black wires with green stripes w/ the white striped ones being negativeā¦
Make sure you keep the negative (-) on the converter to the same on the data cableā¦"
Thanks!
Thanks!
