tko 600!!!!!!!!
RE: tko 600!!!!!!!!
you need a different bell housing and different tranny mounts and if im not mistaken you need a new yoke...you can find them http://www.manualtransmission.com/
RE: tko 600!!!!!!!!
ORIGINAL: timeformiller44
where would i find one to buy!?!??!? will it bolt right up to my gt!?
You will most likely need:
New throw out bearing
Would recommend a short throw shifter, especially with the 600, though not required..
New drive-shaft, and MAYBE a drive-shaft spacer, I'm not too sure about 01 GT's..
New slip-yoke for the tranny
New Bell housing
And to be honest I'd look into getting a beefed up clutch/flywheel if you can afford it, cause the TKO will handle a LOT more power than the stock GT clutch/flywheel will.
Anyway, hope that helps.
RE: tko 600!!!!!!!!
ORIGINAL: Subotai_95
Steeda is pretty reasonable, and I believe Maximum Motorsports, THR, and JEGS have them also.
New Bell housing
New Bell housing
The TKO 600 is also not ideal for your setup, unless you are completely not interested in drag racing. The 600 has a much longer gear than the 500/stock mustang transmissions, which can make it harder to get off the line.
Your going to need a new clutch if you go to a 26T input shaft, which I recommend. You can do this on the 500, but the 600s I beileve are all 26T.
Search tool/stickys own you all!
https://mustangforums.com/m_2832353/tm.htm
RE: tko 600!!!!!!!!
ORIGINAL: 2000GT4.6
You don't need a yoke, short throw, or drive shaft. the spacer is optional, I don't have one. You also don't need a new tranny mount, but yuo will have to notch the stock one.
New Bell housing
New Bell housing
RE: tko 600!!!!!!!!
well i will have a spec stage 2 clutch and all that....so would a tko500 be more ideal to get over the 600 or would i be doing the same things to make them both fit/work
RE: tko 600!!!!!!!!
This is a little confusing to me, because when I had the 3650 when I bought my TKO 600, and both the guys from DynoTuned Performance in VA Beach, and Steeda, and Jegs, all said I needed to get a new driveshaft and slip yoke. They even had to grind a little on the D/S I bought in order to get it to fit, which I guess is indicative of the taller gear in the 600. I also said the short throw isn't required, or the clutch/flywheel unless he goes with the 600 vis the 500, just prefereable at least for me anyway. I HATED the long *** reach to 5th on the stock shifters. Just wonder maybe if I got screwed out of about 800 bucks that I didn't need to spend. lol But I was honestly under the impression you had to have all of that stuff to switch out to a TKO-600 from a stocker 3650. [&:]
ORIGINAL: 2000GT4.6
New Bell housing
New Bell housing
D&D thought I needed a new yoke as well, but I did not. Also, the TKO 500/600 comes with a hurst short throw wich is VERY short. If you didn't get this they screwed you hard, you should not have had to buy a short throw.
There is no way they put the stock 3650 shifter in there anyway, cause it will not bolt up.
What driveshaft did they supposedly sell you? I have never even seen a driveshaft that is supposed to specifically be for a 99-04 GT to TKO swap....
RE: tko 600!!!!!!!!
So far as your clutch, you can do what I did and order a 500 with a 10 spline input, but honestly I wish I had not done this. The 26T is stronger, but in reality you really don't need to worry about it unless your planning on some wheels up launches with slicks, and even then it is much stronger than the stock 45/3650.
Lets put it this way, you are very unlikely to ever break a 500, let alone a 600. If you do, you will break the 10 spline input, and all you would have to do is buy a 26T input shaft, replace it, and upgrade the clutch at the same time.
RE: tko 600!!!!!!!!
ORIGINAL: 2000GT4.6
The TKO 600 and TKO 500 are in the same case, so driveshaft length is the same on both. I still have my stock style yoke. I am acutally running a FRPP alumium driveshaft, which comes with a yoke, that is the part number for the 99-04 GT cars. There should be no difference between a 3650 and 45 in this respect.
ORIGINAL: 2000GT4.6
New Bell housing
New Bell housing
musnicki
09-23-2015 07:11 AM
