Drivers side window problem
Old May 5, 2008 | 11:00 PM
Hash06's Avatar
Hash06
Default Drivers side window problem
my drivers side window will only go up and down when the door is open. i really dont know what can be causing this. when the door is open there is no problem goes up and down like normal. anyone had this problem or know what it might be. it is a 02 by the way
Old May 5, 2008 | 11:24 PM
Stang SS's Avatar
Stang SS
Default RE: Drivers side window problem
i really dont know what could be causing this besides ur weather seals? try having the window down and then closing the door and rolling the window up
Old May 5, 2008 | 11:52 PM
Hash06's Avatar
Hash06
that doesn't work. i have tried rolling up the window half way and closing the door and it wont go up any further. this is annoying
Old May 5, 2008 | 11:56 PM
Stang SS's Avatar
Stang SS
so the window isnt getting caught on anything. So, i have no idea
Old May 6, 2008 | 12:00 AM
Hash06's Avatar
Hash06
from what i can see it is not getting caught on anything.
Old May 6, 2008 | 12:08 AM
Stang SS's Avatar
Stang SS
time to take the door panel off[:@]
Old May 6, 2008 | 05:58 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
You've got (a) an intermittent contact wire in the harness between the body and the door, or (b) the connection to the motor is loose and opening the door is forcing to to make contact. Unfortunately based upon my experience with older cars I think (a) is more likely.[/align][/align]This happens often with automotive wires, in bundles subjected extended flexing. The insulationhardens with age and cracks, the cracked insulation causes a stress point and the copper wire also "cracks" from work hardening.[/align][/align]Take off the door panel as suggested above, and if the connector is seated properly then you'll need to cut open the harness between the body and the door and look for a spot on one of the wires that looks cracked. There will often also be a trace of carbon build-up, caused by arcing of the broken conductor. Look at the areas that flex most first.[/align]
Old May 6, 2008 | 09:13 AM
jjandascog's Avatar
jjandascog
+1 on what he said
Old May 6, 2008 | 04:19 PM
Hash06's Avatar
Hash06
oh boy this ought to be fun, i hope this turns out to be easy
Old May 6, 2008 | 10:27 PM
rossn's Avatar
rossn
There is an adjustment at the bottom of the track that might work. It can adjusted so when the window is being raised, it won't have so much pressure against the seals. It helped on mine.
Spiral534
Oct 6, 2015 04:31 PM
waid302
Sep 14, 2015 11:19 AM
teeeeg67
Sep 1, 2015 11:53 PM
kirk35
Aug 17, 2015 08:42 PM
