Spark plug Problem
Old May 9, 2008 | 08:56 PM
Hatcher514's Avatar
Hatcher514
Default Spark plug Problem
Need help. I drive a 2002 gt vortech supercharged. Well when I get up to full boost in 3rd gear my engine runs like **** after. Because everytime the spark plugs electrodes are bent touching each other not smashed but bent over touch. This happened twice. Once in cylinder 8 and now in cylinder 4. Any ideas?
Old May 9, 2008 | 11:52 PM
dennis_112's Avatar
dennis_112
Default RE: Spark plug Problem
Sounds like you need to run a smaller gap. Try a NGK TR6 gap around 0.32
Old May 10, 2008 | 02:13 AM
Hatcher514's Avatar
Hatcher514
Had NGK tr55 set at .40 instead of the .55but vortech says to use stock gap on the plugs. I'm running about 7# boost.
Old May 10, 2008 | 07:34 AM
RuffCat's Avatar
RuffCat
ORIGINAL: Hatcher514
Stocjk gap maybe but on a much colder plug! That's just what they base their tune from. TR55 is stock heat range. TR6 is one step colder and the 7 series is two steps colder which you won't need for only 7# of boost. Honestly, do some resaerch and get some Lightning plugs. They are by far the best for blower applications hands down. Set them to stock Lighting specs and you will be good to go. But I would def say buy some TR6's for now and gap them at .032 like dennis said. I would get your car on a dyno when you get the lightning plugs and check your air/fuel unless you already have a wideband. I bet your running crazy lean in those upper rpms. I was at the dyno shop when a 03 cobra was running 50:1 at wot above 5k on a 15# pulley. NOT GOOD! It was with a canned POS tune. He picked up 45rwhp and 68rwtq by correcting the air/fuel and timing. Highly reccomend you do that!!!
Old May 10, 2008 | 10:51 AM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Could have serious head issues, but I doubt it if its on different heads.
Good luck getting it figured out.
articman
Jun 21, 2018 11:45 PM
Emblazoned
Sep 3, 2015 10:45 PM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 04:12 PM
