Cams & Springs
Old 05-11-2008, 06:36 PM
jagsfan
jagsfan's Avatar
Default Cams & Springs
I am doing a PI head and intake swap on my 1996 GT and I went ahead and got the heads gasket matched. In addition I installed a set of Comp Cams springs 26113-6 and Comp Cams XE262H. My question is that I was wondering if I need to check the spring pressure on the new springs. My buddy was telling me that I need to ensure installed seat pressure are comparable. He said that if not I can end up with inconsistency between cylinders and my Piston to Valve clearance could become an issue when the engine gets into the upper RPM range. I don't mind taking the heads to machine shop to get them checked, but what is everyone's opinion on this?
Thanks,
Jman
jagsfan is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Cams & Springs
