Great gear write-up and opinions about gear manufacturers
Old 04-24-2005, 08:01 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default Great gear write-up and opinions about gear manufacturers
http://www.corral.net/tech/drivetrain/gears.html
Should I sticky this?
Dan04COBRA is offline
Old 04-24-2005, 03:34 PM
281GT
281GT's Avatar
Default RE: Great gear write-up and opinions about gear manufacturers
I read this article a while back. I have changed grears in differentials of this type in the past and I can say that based on my experience, this article is very good. Even if you've never done it before you could get the job done if you followed this article to the letter, just be aware that the tooth contact pattern is very critical. You MUST be sure to get it right as per the article otherwise you will have premature gear wear and whining sounds.
On a personal note, changing gears in this type of diff is a real pain in the ***. That's why many hot rodders use a Ford 9" because the entire center section comes out and you can work on it on the bench instead of under the car. When I change the gears in my Mustang (when I get it) I plan to get someone else to do it for me. It's such a pain that I'd just rather pay someone to do it. Just my opinion.
281GT is offline
Old 04-24-2005, 04:22 PM
racer02GTstang
racer02GTstang's Avatar
im savin up to get my 3.73's installed cause i dont know how to do it.
racer02GTstang is offline
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
09-03-2015 07:14 PM
09-02-2015 08:40 PM
09-01-2015 08:16 PM
Quick Reply: Great gear write-up and opinions about gear manufacturers
