im throwing codes...help
Old May 25, 2008 | 10:39 AM
grogan's Avatar
grogan
Default im throwing codes...help
i got 2 codes for fuel limit at max and 2 codes for im running 2 lean bank 1 and 2
my car is getting tuned on tuesday but im afraid im not going to make it there. with those codes will i be able to drive the car about 45 minutes away? its been like that for about 3 weeks now and its been sitting in the driveway and my tune appointment is coming up on tuesday and i just wanna know if ill be able to make it there.
ive already turned up the rpms in drive to 710 and the neutral is still at the stock mark at 720. i couldnt get the car to even go into drive when it was at the stock 560 rpm settings. it would just stall.
any help would be apprieciated.
Old May 25, 2008 | 10:57 AM
briansbodyshop's Avatar
briansbodyshop
Default RE: im throwing codes...help
try clearing the codes with your tuner while the engine is running and see if they come back immediately. If you clear the codes and shut off the engine,they will most likely come back if there is a problem. They might not come back while its running. It just depends on what is causing the o2 sensor codes to come up..Some codes wont come back untill you cycle the key on/ off. It wont hurt to try...
mrtrodonet
Sep 19, 2020 03:12 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Drastang
Sep 30, 2015 03:48 AM
firecoyote
Sep 27, 2015 02:37 PM
Offendant
Sep 23, 2015 07:21 PM
