Nx Plate System: Intake Spacer..
Well fellows have a question for everyone. Will the NX Plate system and and intake spacer work together...prob a wild question but if someone knows would you please tell me...because when I order my 75-shot I dont want to have to say good bye intake spacer..
RE: Nx Plate System: Intake Spacer..
It will work together. but I see 2 problems, one you will have a the egr valve fitment issue, now if you delete this it wouldnt be an problem. Then will most likely make the plenum touch the hood
If you want to try go for it, but honestly never seen it done. You will need to use the gasket that came with your intake spacer also.
wow ok fellows...lol I understand loose the intake spacers it was just a simple bolt on as was the rest and I wanted to keep it on the car since i already had it to begin with oh btw the plate system is very very thin....
But thinking about it, if the intake spacer just give you longer bolts then i wouldnt throw it on with the plate system because, even if you could get it to thread it wont be on very tight and you may not get a good seal
jwog666
12-27-2021 08:09 PM
