Quick lifter question please
Old Jun 17, 2008 | 11:01 AM
n0th1n2kn0vv's Avatar
n0th1n2kn0vv
Default Quick lifter question please
I am installing the stock cams on the stock heads with all the stock components. Are the lash adjustersadjustable? Does it matter if I just dropped them in the heads, layed the rockers over top, and tightened the cam with the marks facing up?
Old Jun 17, 2008 | 11:10 AM
black35th's Avatar
black35th
Default RE: Quick lifter question please
Modular motors dont have lifters.
See this thread....https://mustangforums.com/m_1525549/tm.htm (copy and paste)
Old Jun 17, 2008 | 11:41 AM
GodAmGT00's Avatar
GodAmGT00
With that being said....
Ideally, you should soak the HLAs in oil over night, or at least for a little while before dropping them into the head. This prevents premature colapse, which would have you pull a few things apart.. Not extremely difficult, more of a PITA.. Use some assembly lube around the oil port on the top, and on the sides, and you should be good..
JT
Old Jun 17, 2008 | 11:44 AM
n0th1n2kn0vv
ORIGINAL: black35th
Yes, your right.. I guess I mean the lash adjusters. I did not take the cam out of the head and the adjusters and rockers were just thrown in a bag together. Will it make a big difference on the load and everything for each rocker if they are just dropped back in different locations? If it will, how can I figure out where to put them?
Old Jun 17, 2008 | 11:48 AM
n0th1n2kn0vv
ORIGINAL: GodAmGT00
JT
Ok, just use the old oil for the overnighter? Should I bleed the air first?
Old Jun 17, 2008 | 12:06 PM
GodAmGT00's Avatar
GodAmGT00
Well, soaking them in oil over night tends to bleed all of the air out of the new ones..
As for the followers (aka rocker arms), ideally, they're supposed to be matched the exact cylinder/valve that it originally came from.. Depending on the mileage of the engine, and the condition of the followers/HLAs, you my not have any problems, but I've never mis-matched these things when rebuilding an engine, so I don't know specifically what could happen. I was always told to keep them together..
JT
Old Jun 17, 2008 | 01:14 PM
n0th1n2kn0vv
ORIGINAL: GodAmGT00
JT
The engine has 69,000 miles on it and there is no apparent wear on the HLAs or the followers. Does that mean anything? I was given two sets of HLAs and followers for the PI heads (I dont have the heads) and I measured half of them to see what the difference was. Almost every one was different by a couple thousandths. They were all between 1.990" and 2.002" (One was 1.975 for some reason). But I am not sure if that is significant because supposably they are hydralic?
Any information will help. Thanks in advance.
Old Jun 17, 2008 | 01:19 PM
GodAmGT00's Avatar
GodAmGT00
Well, in theory, being an automatic lash adjustment should alleviate any type of discrepancy between them, but like I said, I don't have any personal experience mixing and matching followers.. My father always said that the cam and follower wear specially together, so I just took his word for it...
JT
Old Jun 17, 2008 | 02:05 PM
n0th1n2kn0vv
Well, I guess the only thing to do is try it out. How would you figure out where to place new HLAs if you were to buy another set?
Old Jun 17, 2008 | 02:13 PM
GodAmGT00's Avatar
GodAmGT00
Well, normally, you'd replace a follower and HLA as a set, and all of the times I've replaced them, I've replaced the cam(s) at the same time, so it was never an issue, however, if it's new, I can't imagine it make a huge difference, although like I said, as things beat on each other for thousands of miles, they tend to form specific characteristics of each other.. I don't think I've ever replaced an individual follower, rocker arm, lifter, HLA, or push rod, so I really don't know.. I'd say, as long as it's charged (soaked in oil), and there aren't any major discrepancies, you could put it anywhere you'd like.. Then again, I have no experience in mixing and matching, so please understand my reluctancy of just telling you to just do it a certain way..
JT
