o/r x pipe help!
o/r x pipe help!
finally bought a o/r x-pipe and before it gets here in couple days i had a few quesstions. How will the installation take? and will i be ok by using a jack and 2 jackstands to do it?
RE: o/r x pipe help!
The length of the installation completly depends on how hard it is to get your stock H off. A midpipe swap can be done in a 1/2 hour unless you run into problems.
Just remember to soak the f*ck out of those bolts multiple times with some PB Blaster. Get a 2 foot extension, a swivel, 13mm and 15mm sockets, and I think a 7/8 open end wrench for the o2 sensors.
^ What he said. PB Blaster is your friend on these installs. It soaks into the bolts and makes them much easier to get off.
Also, make sure you have a new gasket for the passenger side. You cannot re-use the stock one and if you don't put one in you will have an exhaust leak. You can get it from Ford parts department and it is about $10. You may be able to get it from an Autozone or something, call them and ask. You do not need one for the driver's side.
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
