E-Fan Remote Switch
Old Jul 7, 2008 | 11:10 PM
Racing2fast's Avatar
Racing2fast
Default E-Fan Remote Switch
I cant ever seem to get the "search" feature to work on this site for some reason.
Not to long ago, there was a thread on here about how to hook up a toggle switch to control a E-Fans on the Mustangs. I was looking for that thread, as it had a diagram, and a certain wire that you could tap into from the ECU to bypass and turn the fans on manually. (sitting in the staging lanes with the car in Acc. mode and allow the fans to run for a little bit to help cool the car)
If someone can find this will you post a link,
If someone can explain to me how to use this sill azz search function I'd be appreciative!
Thanks In Advance!
Tom
Old Jul 8, 2008 | 12:08 PM
Houghtown's Avatar
Houghtown
Default RE: E-Fan Remote Switch
I thought that I just didn't know how to use the search function.Good to see that it isn't just me that is having issues with thesearch. Anyone know how to use the search function?Or maybe it's just us two[>:]
Old Jul 8, 2008 | 01:52 PM
blackstallion666's Avatar
blackstallion666
ORIGINAL: Racing2fast
Thanks In Advance!
Tom
what year is you car??? and i'll lokk it up
Old Jul 8, 2008 | 01:57 PM
35thAnni99GT's Avatar
35thAnni99GT
From: Where gunshots are more common than birds chirping
Just find the power wire to the fan, splice into it, run a switch between that and a fuse on the distribution block, and it should work.
Old Jul 8, 2008 | 02:14 PM
shakenbake16's Avatar
shakenbake16
im also trying to find out how to do the same thing. and search isn't working for me neither.
i have a 98.
Old Jul 8, 2008 | 02:20 PM
35thAnni99GT
Your fan will be grounded already, so all you need to do is find the power wire going to it and energize it.
Old Jul 8, 2008 | 02:24 PM
blackstallion666
ORIGINAL: shakenbake16
i have a 98.
for you its pin 46 at the pcm/ its a light green wire with a purple tracer.All you have to do is tap into that wire and run it to a switch. and from the other terminal on the switch you would run that to ground. And your good to go. The cooling fan will work like normal and when you want it on just flip the switch. The only crappy thing about wiring it this way is that the key has to be in the on position to work.
Old Jul 8, 2008 | 03:08 PM
shakenbake16
ORIGINAL: blackstallion666
i have a 98.
that sounds pretty simple, thanks alot man
Old Jul 8, 2008 | 03:37 PM
blackstallion666
not a problem.
Old Jul 8, 2008 | 10:51 PM
Racing2fast
BlackStallion!!!
I have a 2000 Stang Gt.
If you can look it up I'd appreciate it! Where do you find this stuff?
Thanks Again!
Tom
