Wideband 02 systems?
RE: Wideband 02 systems?
ORIGINAL: jjandascog
If you have cats it seems that installing the Wideband O2 sensor downstream of them will not give an acurate reading?Does anybody know if that is true or is there a calibration factor that takes this into account?
My last s/c kit I built I went with summit's wb kit ($250)
Uses the lc-1 controller with a gauge. Cheaper than ordering innovates kit with the gauge.
I've used the aem 6in1 aswell. They're pretty cheap if you get them off of ebay. (around $240 after shipping)
both come with the controller, gauge, & sensor.
Readings after the cat are pretty accurate.....at higher rpm / load. The cats have liitle to no time to react chemically at high rpm. Idle and cruise it should read 14.7-14.6...cats working. I do not recommend this way though!!!!!!
We use the innovate and Sniper.
Casey
Casey
I would recommend going higher than 14.7 for cruise conditions for better fuel economy. I've ran two cars up to the 16's. The last one I did was set at 16.3:1 at cruise. Not all are the same though, some cars can go higher. I adjust up until surging then back off .2-.3
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
